sherwind2010
You can put a Kraken G12 with a EVGA CLC 240 on a MSI 3060 Ti VENTUS 2X OC. It goes back to using the NVidia brackets. where the 2080 used the AMD brackets. Temps before was around 65c on stock cooler now it is 38c with AIO, It may have boosted the clocks a little bit having the AIO on maybe upped 1FPS at most in 4K. XD
PS: Oh yeah!! You need to drill wider holes on your Kraken... That is it.
