fefox
so the heat from one GTX 295 folding was just about killing me (I have no aircon) im about to fire up 2 more.. so I decided to try and COOL the room down... with stuff I had laying around.... so far its working great.
my house is ancient, its got a basement with a well in it and about a 35 gallon SUMP pit.. the water table is almost as high as the floor in my basement so im pumping out the sump pit about every 5 mins, the water in the pit is COLD like 55F so cold you can't keep your hand in it for long before your muscles stop working and it hurts like hell..
I put a small pond pump into the sump that sends water upstairs to the computer room thru a small rad with two blowers on it and then the water returns to the sump. nice part is the sump is emptied every 5 mins outside and fresh COLD water starts to refill the sump..
now It's freezing in here!!
what im thinking of now is a sealed enclosure with the rad in it pumping all the heat out... and keeping my room quiet! the blower on high is im guessing about 70db
Ive had it running for a few days on top of this rubber lid cause it does drip condenstate at times.. :biggrin:
