My Seasonic TX-750W tripped breaker or it was halogen bulb in bathroom?
Status
Not open for further replies.
sew333
PC: Aorus AD27QD
AORUS PRO Z390-PRO GAMING
Aorus 2080 Ti waterforce stock
2x16GB DDR4 GSKILL XMP
9700K STOCK
Seasonic TX-750W TITANIUM PLUS PRIME
Pc was on idle and monitor was on. Other devices like tv,washer off. So not circuit overload. 2 weeks ago something tripped 2 small circuit breakers . All electricity lights and sockets went down .Then.......i go to bathroom and saw that one of 3 halogen bulbs no lightning. So one bulb get burned.
What tripped breaker? Halogen Bulb or Seasonic psu of my pc?
Like i said pc working normally after that outage.But i am worried about my psu.
Thx for helping me. I am not cooled down<lol>.
clshades
Big White Ski Resort
That circuit sounds like it's overloaded. You'd need a clamp meter at the breaker box to know what it's pulling with everything on. Switch your halogen for LED. Best thing I ever did man. Took my house lighting from 3500kwh to about 40kwh. More importantly, I don't lose my mind when the lights are left on.
sew333
It was not overload circuit because i had only pc on desktop. Also tv,washer was off. Only 3 halogen bulbs was ON in bathroom. So my question. It was caused by one from three bulb that get burned or psu inside pc?
Entz
Kelowna
If two breakers flipped at the same time I would be concerned there is a multiple wire short somewhere. Could be animal caused, could be heat/mechanical stress/etc.
I would second the "you should get someone to look at it thing". Last thing you want is a fire.
sew333
Not. Because year ago we had washer overloaded and always was tripped 2 breakers. When we put less clothes no tripping. Its just a way what my house is wired.
Entz
Kelowna
Wait are you talking about a double pole breaker (2 arms are linked together aka common trip) or 2 separate independent ones?
If it is a common trip one then its simply because the lamp died (likely shorted) and it took another circuit out with it. That is just bad design imo unless there was a good reason.
Sagath
Folding Team
Edmonton, AB
Great. Then call an electrician. You clearly know its not the computer PSU and the fault lies with your house.
Status
