Need an opinion on this PC Build (First Build)
Wrekt--
New member
I am planning to build a gaming PC and i wanted to know if these parts are good
CPU: Ryzen 5 3600
GPU: Gigabyte geforce GTX 1660 Ti
Motherboard: ASUS Prime X570-P
Ram: Patriot Viper Steel DDR4 16GB 3600MHz
Case: NZXT H500
moocow
Vancouver, BC
It's fine? I suggest you find a set of videos on X570 motherboard reviews on YT. If I recall correctly, his opinion that anything below $200 are crap and above $300 are overpriced. What's the price difference between the 3600MHz and 3200MHz? I personally wouldn't go above 3000 or 3200 since the difference is little.
JD
Toronto, ON
If that's the set of Patriots that I've seen posted elsewhere, they are really cheap for 3600MHz.
What power supply are you planning to use? The rest looks good though.
Wrekt--
New member
The Ram in the build is $119.99
and the other RAM is a XPG Gaming D10 3200MHz 16GB $99.99
The power supply is a Corsair CP-9020177-NA RMX Series 550W
Fully Modular (2018) 80+ Gold
moocow
Vancouver, BC
I would go with Seasonic Focus Gold Plus 550W for the same amount of money. That Corsair unit is built by CWT which doesn't have the same rep as Seasonic. RAM wise, I personally would put that $20 toward something else.
