Need help finding this cable.
wade7575
I have a front panel for my tower that use's this type of connector to plug into the motherboard,I'm trying to find the same cable that has the 2 screws I circled in red.
I find the same cable but not with the 2 screw holes circled in red and I can make one of them work I just need to drill 2 holes in the panel so I can use the other 2 holes on the plug.
sswilson
Moncton NB
Have you checked with the case manufacturer?
A quick search suggests that the 90 deg screw placement on your cable is not industry standard, and might only be available through the manufacturer.
Izerous
Folding Team
Edmonton
functionally having the screws at a 90' angle makes very little sense for a lot of things. I/O shield, standard panel etc going to want inline screw holes. Your might be a 1 off design, even looking at your photo the shape of the connector it almost just looks like a modified inline one in the first place. Had it been designed from scratch for screws to be angled like that they would have made the mounting surface flatter to make a more rigid mating/mounting surface.
Heat inserts and a drill and some epoxy (to fill in the old holes) would be the hacky solution but it might be the only one besides ordering it pre-made from the case vendor.
wade7575
Their were of no help.
wade7575
I the reason they put the second screw holes in that way was so that it makes for a cleaner look,the 2 holes I circled in red the screws go threw the PCB and then into the connector to hold it in place that way the screws aren't seen.
I personally don't care if I have to drill the front panel of it to use the screws in the front.
https://www.amazon.com/GRAUGEAR-Int...295283&sprefix=3.5+front+panel,aps,160&sr=8-4
