Want to Buy Need Help getting a Front Panel Extension **Found**
Shadowarez
Folding Team
Age
43
Yellowknife Canada
Good Morning all im in need of assistance from community i need a part for a motherboard to complete it but having no luck tracking one down. board works but with now Front panel i will have to open glass panel each time it needs to turn on PLS Help with your google fu magic.
part# 12CF1-1IA002-01R
this is for this board Gigabyte X570 Aorus Extreme
Is this originally part of the motherboard or part of the case? If it's the motherboard part, any reason (other than the obvious aesthetic ones) you couldn't bundle 2 pin jumper extensions in heatshrink if the existing case front panel cables are too short?
It's not completely sure what issue you're having.
edit: Or is the actual FP header on the motherboard completely proprietary and can't be accessed with the normal size jumpers? (If that's the case, that's nuts, and never should have been incorporated into the board!).
its from the motherboard it needs this particular extension because they went proprietary with this connector the FP on the Case itself isnt split either its all combined into a housing like usb 2 internals are itd need to connect to there cable to work,
So it's that connector there? Damn.... I can't imagine you're going to be able to find something to take it's place if Gigabyte doesn't have it. :(
seen that as well but not 100% confident id get it right if the first one just fits in the spot i could attempt it but would hope for a safer solution. did my searches weeks ago tried reaching out various places inc Gigabyte usa via X (Twitter) and Radio Silence since thought well if im getting nowhere maybe others have or can help in creating this.
