Need help with new build
Ryan S.
New member
Budget $850 Use: Gaming/VR/Streaming
Cpu: Ryzen 5 2600
Motherboard: Gigabyte B450M DS3H Micro ATX AM4 Motherboard
Ram: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3000 Memory
SSD: Kingston A400 240 GB 2.5" Solid State Drive
Graphics Card: Gigabyte Radeon RX 590 8 GB GAMING 8G Video Card
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case
Power Supply: Corsair CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply
Monitor: Acer KG221Q 21.5" 1920x1080 75 Hz Monitor
Keyboard: Redragon K552-R KUMARA Wired Gaming Keyboard
Mouse: Redragon COBRA M711 Wired Optical Mouse
Current Price: $686.59
Any tips on what to change?
JD
Toronto, ON
I would go with a better SSD and ideally M.2/NVMe, look at possibly the Crucial P1 or WD Blue as affordable options, or move upwards to the Corsair MP510, HP EX950, Adata SX8200 Pro. And get at least 500GB.
Might be better off with the Ryzen 3600 instead as you can gain about 20% performance.
I'd try to get at least a 24" monitor too, but that's totally up to you.
RX 580 vs RX 590 isn't a huge difference, so I'd drop down to the 580 if you need to save a bit to afford the other things. Altenratively, you could consider the GeForce 1660 Ti too as it offers more performance without blowing your budget either.
Bond007
Nova Scotia
Remove the a400 ssd. Get an nvme ssd instead. Even a cheap intel 660p or crucial p1 (budget nvme) will be a plus (and no wires). Get 480+gb.
Edit, JD’s post has more detail. Concur.
Ryan S.
New member
Cpu: Ryzen 5 2600
Bad news: price for an item got raised. Final price now $697. Thanks to all who are helping me out.
