Need help with Upgrading my system
Coach
Morden MB
I bit of both, I really want 4k gaming but the system is not up to it, frame rate drops to about 30fps in codmw and mid 30 to 40 in AC Valhalla
IMO you need a better GPU to run 4k. As you increase your res the potential "bottleneck" of your CPU decreases. First get a better GPU and then consider a newer CPU.
Sknight
Member
There is only one version of the board and that link is correct. The M.2 slot us under your graphics card. Remove the GPU to get access to it.
Bond 007
if you look at the picture i put in the post there is nothing under the GPU card slot
Coach
Morden MB
Like Bond mentioned, take out your video card... You will then reveal the m.2 slot. Your idea of under is different than his idea of "under". We are not referring to the Y axis, rather the Z axis... if that helps.
Bond007
Nova Scotia
You literally need to REMOVE the graphics card. It is blocking you from seeing the m.2 slot.
moocow
Vancouver, BC
Here's a video from Optimum Tech reviewing 10 series in 2021. He did include the 2060 Super in his chart and you can see it can barely crack 60 FPS in 1440K, you can basically forget about 4K. I think it would be wise to wait a month and then go to AMD's website and order a 6700 or 6700 XT right them on day one.
Sknight
Member
wow that is an eye opener thank you
