Need some help.
rsnt
Member
Mississauga - TO
Hey guys;
I'm planning to mod a CM stacker STC-T01 I bought a couple of weeks ago to fit 2 x 120mm fans on the top, 3 x 120mm on the front (turbine mod, without fiberglass) here an example of a turbine mod:
techPowerUp! :: Case Gallery : Antec 900 Turbine
Now imagine that x 3 :biggrin:
Anyway, to do this I'm going to need a few things I was able to find at casemodstore and this is what they have I would need:
1. UChannel
2. FanDuct
3. MnpctechBilletFanGrill (for top fans)
4. FanGrommet
Would anyone know if these can be found at a Canadian retailer? I'm pretty sure the fan grills can't be found since they're custom, so don't worry about them.
Also, what's the standard 120mm fan screw size? I need to know this because I'll need longer screws for the turbine mod. (They'll be used to fit an aluminum sheet, fan, fan filter, 4-in-3 device module)
Did you try bigfoot computers?
They used to have a fairly large selection of modding gear.
As far as the screws go.... just take a standard length one down to your local hardware store. They'll have longer ones in the same thread.
Haven't really checked bigfoot but I will when I wake up, thanks :)
That Antec Turbine looks really nice. I wonder how much money the guy invested, and, where are the power on, reset buttons? :haha:
Maybe try bigfoot as wilson said. Also, check out Xoxide.com and NCIX.com
Personally, i always find everything i want at Performance-pcs.com
