Network Map drive Slowdown?
Shadowarez
Arctic Canada
Anyone Experience mapped drives from a wired server slowing by 2-3 seconds a week? From instant access to 2-3 per folder in shared drive.
Rig in Question is a Acer M3970 which I loaded with 26gb of Mushkin Blacklist ram. It has a i3 Quad core running 3.2ghz.
The main boot drive is a Samsung 850 Pro 128gb the other drives in server is 3 Wd Red 3Tb.
When I first set the server up I installed windows 8.1 Enterprise. Installed chipped video and magian for rapid. The drives are about 75% full videos pics backups. But I spanned them together instead of raiding them.
For over a month I had zero delay in getting to shares instantly now it's beginning to slow down to a point it needs to wait 2-5 seconds before it opens a folder which right now isn't a big deal what I'm worried about is if I can't find cause of slowdown how much more will it slip at accessing the shares.
Iv done some searching and it's one of 3 things indexing is not working or somehow the prob. A bad network cable. Or my $279 Asus Router is slowly dying. I'm considering replacing all cat 5 email cables with cat 6 to give better bandwidth throughoutput.
JD
Toronto, ON
Yeah, definitely sounds like a network issue. Maybe DNS?
If you ping the hostname of your server from your desktop, what's the response like? <1ms?
And I presume you've rebooted everything? :bleh:
Shadowarez
Arctic Canada
Oh yeah even wiped drives and copied from back up. It worked fine for lil over 8 days then started crawling to 1-2-3-4-5 seconds to access any folder within shares.
Shadowarez
Arctic Canada
Found issue its weird but it seems connecting to shares with a account I setup on htpc was issue I let windows default for shares speeds back to 110-125 mb transfers.
