New 7970...already Dead? :angry2:
HoserEh
Vancouver Island
Like the title says, I believe I may have a faulty card.In firefall Sleeping Dogs and Dirt Showdown i see screen tearing and artifacts, and if I OC any farther then 1000 mhz on the gpu it crashes....memory can only go far as 1400 then crashing (975/1375 is stock). My specs are in my sig.
HoserEh
Vancouver Island
stock is stable is in no crashes but the tearing and artifacts appear after about 30 minutes of gaming.Temps sit at max 71C but average at 68C
BeaverBender
Montreal
I'm wondering if there is a bad batch out there. A couple of my friends recently purchased 7970's and are having similar issues. What was the manufacturer?
Dazastar
Member
Usual driver thing!
Same happened with Skyrim (bad artifacts and tearing)until they released a driver update and work around for it.
My only complaint with ATI is this seems to be a constant, they seem to release cards prematuraly and give us users driver headaches. Other than that they're a great card.
HoserEh
Vancouver Island
Funny thing is i had Beta 12.11 before and it was worse....with 12.10 i get 30minutes up to an hour before it tears and artifacts.
sswilson
Moncton NB
Have you tried running some form of GPU stress test to see if you can reliably duplicate the issue? Furmark still works, but IIRC you have to chose a non-default test otherwise the driver recognises is as a stress test program and drops the power use down (that might only be with Nvidia though).
I had to do something similar with an old sapphire 1950pro. I had it down to where I could pretty well guarantee that the test would failr within a 5 minute window and when I presented my findings to the retailer they just replaced it straigtht out with one of the newer versions (improved VRM to prevent overheating issues, but Sapphire never admitted fault).
