Gallery New 9900k Build.
crazyea
Surrey, BC
Here is my new 9900k Build. Funded by the CRA (and Lysrin).
Parts List:
Intel® Core™ i9-9900K Processor
Noctua NH-U12s
Noctua NA-HC2 Chromax White Heatsink Cover
2x Noctua NF-F12 PWM Chromax Black Fans
ASUS ROG MAXIMUS XI EXTREME
Trident Z RGB Series 32GB DDR4 3200 (F4-3200C16Q-32GTZR)
2x 970 PRO NVMe 512GB SSD
2x Western Digital Black 6TB HD
Fractal Define R6 White TG Case
Phanteks Halos Lux Digital LED 140mm Fan Frame
Evga SuperNOVA 850 P2 Power Supply
Logitech G PRO Optical Gaming Mouse
Logitech G Pro Mechanical Gaming Keyboard
crazyea
Surrey, BC
This is the build in the first layout.
Then my son suggests I adjust the usb 3.1 cable for less tension.
crazyea
Surrey, BC
But the hard drives were idling at 49 degrees so installing them behind the wall was not a good idea. And I preferred the look without the cable extensions.
crazyea
Surrey, BC
No gpu. No money left. haha.
Seriously though. I game on the ps4 mostly. I use this for web surfing. And its a Plex server for my family. It serves 10 or so people movies and tv shows.
But when I come into another windfall I will try and get a 2070 or similar level gpu. who am I kidding I will probably try to get a 2080 ti for youtube. Overkill is my thing.
danmitch1
Ahh ok ic. The integrated graphics on that 9900k should suffice for sure then.
rjbarker
Courtenay, B.C
Very nice....tidy.....the one thing I really like with the IGP is being able to test everything out of the box if you dont happen to have a GPU available....
I was able to get my 9900K rock stable at 5 Ghz (all cores) and the last few days more tinkering reached 5.1 Ghz (all cores) / 4.8 Ghz Uncore (Cache)...thats the upper limit though as even with a Custom Loop I was getting peak temps on a couple of cores to 91c running P95 ....and that non AVX......w AVX forget it ;)
