New build DOA
Shadowarez
Arctic Canada
I'm starting to think this Apex board wasn't a sealed unit but instead a rma that was denied.
I can't get windows 7,8.1,10 or Linux installed no matter the settings in cam on off, windows Uefi on off, won't install on the Dimm.2 ssd or a Samsung 850 Pro Sata ssd
IV updated the bios 1404 tried everything.
Need some help here before I open a ticket have this board refunded for being Doa.
Shadowarez
Arctic Canada
It seems to fail at 60%on every USB key whether it be mbr GPT that's were it gets the message of corrupt install iv even tried the iso direct from Microsoft with media creation tool.
Cptn Vortex
Vancouver
I had a similar thing happen a while back with a X58 system and i7-970. In the end, the i7-970 had one of those tiny resistors/capacitors on the underside of the CPU burnt/cracked. Poped a new CPU in and it worked perfect. That was definitely a tough one to troubleshoot.
Shadowarez
Arctic Canada
Hope not I'll try new mobo
I'll try my gigabyte aorus Ultimate then on weekend meantime I'll open a ticket to refund this pos.
Shadowarez
Arctic Canada
Well got rig up and running I used Data migration from my server to the 850 pro ssd now I just need to find drivers for this Apex board and win 7 hope there is some. For chipset. Really don't want windows 10
Shadowarez
Arctic Canada
This board is the x299 board i9 7980Xe CPU atm win 7 is Running I'll try getting drivers installed what I need Is a external DVD Drive I'll install Motherboard drivers then update
Shadowarez
Arctic Canada
Update waiting on rma memory to rule out faulty sticks. Rampage Apex is being refunded by eBay so not sure what to do with board upon changing boards I seen top right of socket has a batch of bent pins I looked before installing and when started acting up didn't see them till board was packed up. Can the board be salvaged or should I keep as a expensive paperweight? EBay said I can keep board lol.
