New build problems
kING4000
Active member
Toronto
i got components to build a new system and at the end i am having few issues. the system acts on its own and chooses 1 of 3 things to do at power up:
1. the computer starts but i get nothing on the screen (42%)
2. the computer starts, shut downs in few sec and starts up again, with blank screen on the monitor (42%)
3. the computer starts up(6%)
when the computer chooses 1, the motherboard is getting the power, all the fan attached to the motherboard works, cpu fan works, the monitor wakes up from sleep mode and goes back to sleep mode
when the computer chooses 2, the motherboard is getting the power, all the fan attached to the motherboard works, cpu fan works, the video card fan starts up at full speed the monitor wakes up from sleep mode and goes back to sleep mode
when the computer chooses 3, the motherboard is getting the power, all the fan attached to the motherboard works, cpu fan works, the video card fan starts at full speed and thn drops to normal?! level, the monitor wakes up from sleep mode and works fine but gave me blue screen of death once, froze again
so that is what seems to happen with the system and it is made up of
p5q e - motherboard
bfg 280 gtx
2gig ram
500 Gb HD
750 watts psu
i double, triple checked the wiring for the power if anyone is wondering.
3.0charlie
Bedford QC
Have you tried raising the Vcore by just a tad more than stock? The CPU may be low on Volts to be stable. Also make sure your ram has enough volts too.
