Long time listener first time caller...
It's been a while but I'm looking to upgrade my gaming PC and to be honest, I've fallen way behind on technology and have spent a few days combing through whatever information I can find but I am still at a bit of a loss as far as the motherboard goes. (B450vsX470vsX570) I am going to be reusing parts of my current build (as noted below). As you can tell, I don't upgrade too often so keep that in mind.
Purpose: Gaming 100%
Budget: Noted next to components otherwise assume best value
Country: Canada
Brand Preference: None
Reusing Parts: Yes - as noted
Overclocking: Possibly but not necessary
When: Within 2 weeks
Resolution: 2K
Tech Requirements: Nothing specific - RGB is not a selling factor for me - If it has cool if it doesn't then that's fine too!
Current Build:
Gigabyte Z77X-UP7
Intel i7-3770K
4x4096 G.Skill TridentX DDR3-2400
Asus Dual GTX 1070 8GB
Cooler Master M2 1500w PSU
Phanteks Enthoo Luxe
Samsung 860 EVO 500GB SSD
Proposed Build:
Motherboard Unknown (HELP) - Budget Up to $250
AMD Ryzen 5 3600X - $269.99
Corsair Vengeance RGB PRO 16GB (2x8GB) DDR4 3200MHz C16 (Unless other recommendations) - $119.99
Asus Dual GTX 1070 8GB (Reuse)
Cooler Master M2 1500w PSU (Reuse)
Phanteks Enthoo Luxe (Reuse)
Samsung 860 EVO 500GB SSD (Reuse or Replace with NVMe if it makes sense)
Thanks in advance!
Slaughter
Country: Canada
Resolution: 2K
Current Build:
Gigabyte Z77X-UP7
Intel i7-3770K
Proposed Build:
Thanks in advance!
Slaughter
