New Build, won't start
biff
Courtice, Ont.
Well I wasn't going to candy-coat it! LOL. But seriously I have seen it, shorting either the 5V or 12V to the mobo tray. The psu sees the over current and shuts itself off so no damage is done.
shryke
Active member
Ok guys, I unplugged everything and then put it all back together and it works now.
I don't know what happened, but I THINK it was the 8-pin 12v .... whatever that is not being in correctly or soemthing,.
Thanks for all the help anyway!
SugarJ
Langley, BC
That's what powers your CPU, and the behaviour you're describing is exactly what happens when you forget to put that plug in. It's my favorite thing to leave unplugged when I build new systems. :biggrin:
3.0charlie
Bedford QC
It's always the first cable I plug, while installing the board - since that connector is always located in such a awkward location with those huge aftermarket HSFs.
SugarJ
Langley, BC
Most of the builds I do are for small business. Stock HSF's only. But yeah, after doing that a couple of times, it's pretty much the 1st plug in the board after screwing it down.
