New EKWB pressure/leak tester
sswilson
Folding Team
Moncton NB
I saw this yesterday and wondered if anybody was going to bring it up... :)
It got me wondering about the pros/cons of using pressure for this purpose... we used vacuum when testing torpedo components for leaks, I wonder if the only real difference between using pressure vice vacuum would the the possibility of collapsing your tubing under vacuum?
Lysrin
Nova Scotia
I'll bring it up!
I think you could have issues either way. Too much pressure resulting in seal damage; vacuum, as you said. That is why I thought it was a nice touch that they included a "safe zone" marking on the gauge.
clshades
Calgary
A 15psi test would be more than enough. This is the standard for testing gas pipe. Does anyone know what the water pressure typically is when water is in the loop?
If anyone out there wants to try all you'd need is a 30 psi gauge.
Bartacus
Ottawa, Canuckistan
I've never seen the need for these things. Once you have a leak or three, you learn what to check for. Leaks are rare once you get the hang of it, and unless you have something like a defective rotary fitting, you rarely see leaks unless you goof up (ie not tightening up a fitting properly, etc). Tools like this appeal to new water coolers, since it provides that security blanket, but leaks aren't a serious issue in water cooling, at least not for me.
Entz
Kelowna
Indeed, I haven't had many issues in what seems like forever. I don't use fancy coolant anymore (NEVER EVER EVER again) so a little leaking is not an issue and fixed with testing. But I also have a 120v to Molex adapter that I got from DazMode ages ago and never run the machine till I am 100% sure.
Many moons ago (think decade) I did puncture a radiator though due to the horrible manufacturer tolerances at the time and it may have been nice to find that out before doing a leak test and creating a sprinkler, but it didn't harm anything (Distilled water :love:).
rjbarker
Courtenay, B.C
Agree.....I think Im old school I suppose.....like to physically run liquid thru the loop...only ever had 1 leak ...was my fault totally....o ring not seated correctly on SLi Bridge.....no biggie...dry things up...go at it again....
OverkillYJ
Langley, BC
I purchased one of these and I think it's great. I always hated the leak testing process. This speeds up the process a lot and you can go straight to your coolant and skip the distilled water step.
stlouis1
Ottawa
I bought one of these last week as well to use on that mitx build I'm working on. The build is so tight that it seemed like something that might be useful to have for leak testing before I put water in. We'll see how it goes soon enough
OverkillYJ
Langley, BC
Only issue i had was with my heatkiller reservoirs. The pressure popped the lid on them just a bit until the lower end of the target pressure area. Took me a while to learn that one. I have an extensive loop with 2 blocks, 3 rads, 2 reservoirs, dual pumps, temp and flow meters, top and bottom drain ports, etc. so there are a lot of places for a leak. I am happy with this investment.
