New Gaming Build?
LegendofJubei
Gaming
$5,000 max.
Canada
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
None.
N/A
Yes.
Overclocking.
Within the next 30 days.
Hoping you can help me out with advice for this new build :biggrin:. I've tried to compile something that I think should work. Here are the components so far:
Case: Coolermaster CM Stacker 830 Evo
Mobo: Asus P5Q Deluxe
CPU: Intel Core 2 Duo E8600
RAM: Mushkin Ascent PC2-8500 4GB DDR2-1066
Video Card: HD 4870 X2
Optical Drive: Samsung SH-S203N
Hard Drive: Western Digital Velociraptor
PSU: Silverstone Strider 850W Modular
Heatsink: Thermalright Ultra 120 Extreme Black Edition
Heatsink Fans: Scythe S-Flex SFF21F x2
Sound Card: Xtremegamer Fatal1ty Professional Series
Speakers: Logitech Z5500
OS: Windows Vista Home Premium 64-bit
Mouse: Logitech G9
Keyboard: Logitech G15
Monitor: Samsung 305T 30IN
Thermal Paste: Arctic Cooling MX-2
Other: AeroCool Silver Lightning 120mm x4 (three for side panel/1 for top of case). Apparently the top left fan needs to be removed on the side panel for a tower heatsink.
Total price comes to around $4,334 without any price matching.
I don't know if I am fully happy with this build or not. I'm sure I messed up alot of the parts and could do better? That's where you all come in with your knowledge :thumb:. I'm feeling some of the weak links at the moment may be the CPU/Mobo/Ram. Maybe it would be better to go quad core/ASUS Rampage Extreme X48 mobo/ddr3 ram? I'm sure I could still fit within the price range with a few upgrades/part swaps?
Thanks for any input! :clap:
cwestwell
NWT
wow that is some serious $$$ to spend in one bang but there is definitely some nice parts there. I would maybe get a smaller monitor a 24" or 27" inch the price jump to 30" is so huge however a good monitor is always a good long term investment but I think a 27" would be more then enough and you would save $600 to $800 thats another 4870X2 if you want mad GPU power or a ASUS Rampage Extreme but if you are not going to Water cool then its a waste. So maybe spend the difference on a good Water Cooling setup and an awesome MB.
SugarJ
Langley, BC
If it's a pure gaming PC, duo's outperform quads in most current games due to the higher clock speed. Grab a E8400 or E8500 and save yourself a couple hundred dollars, they'll clock to 4.0 GHZ easily. Now you can probably put the Rampage in the budget. And some LN2.
Wish I had 5k to blow on a computer. Good luck with your build:thumb:
Dashock
Toronto
Yes you are spending some serious cash my man if your going to spend that much id suggest you wait for the I7 i mean you obviously have the money and itll cost just the same. P.s the 8600 is not worth the price wait for a price drop.
