New gaming pc build please help
moocow
Vancouver, BC
OH GOD NO! I meant switch the thermal paste to another brand that is well known and tested. Absolutely use thermal paste even if it's the stuff that came with the AIO or whatever air cooler you decide to use. I also just notice that the case doesn't have a price on Amazon so the price is most likely to increase by $200. I wasn't sure if it's the same case in your original post since that didn't have a model number in the screenshot.
MvSlainXVII
Active member
Intel for now is best but if you can wait out for the 3950x till november than it's okay but i will advise to use moocow's Amd build if you are going AMD than intel.
