new gpu install-post code62
jtf2
okay thought i would start a new post to cover this new issue
as i posted previously
1080 gtx installed into other pcie slot on asus hero viii
moved pcie connectors from 780gtx to the 1080
display port and hdmi plugged into 1080
it starts booting process card lights up
but no screen display just sits at post code62
which my understanding is
installation of pch runtime services
so i turned it off,put the cables back on the 780 and here i am
i did see in the device manager the 1080 card so thats good
fwiw the bios i am using is 3401 which is from 2017
could it be possible a newer bios is needed to recognize that card?
will keep poking around to see if i can sort this out
MARSTG
Montreal
And if you try the onboard ? Connect display cable to onboard only, go to bios, select to initialize the onboard gpu only, save, shutdown. attach display cable to 1080, reboot, in windows go to display properties select to display windows on both monitors , clone style. Then switch to the display with the 1080.
But why don't you remove the 780? is it part of a hard to disassemble water loop?
jtf2
hmmm thanks for that idea
i will try that shortly
is it possible the bios needs to be updated?
i am on bios3401 which is dated 4\7\17
newest bios for this board is 3802 dated 4\27\18
i am not sure where on the gpu any onboard leds are,as my case is an inverted setup,so can`t see any diagnostic leds etc,to give me a clue on that side of things
yes i do not want to tear down the loop until i have the block for the gpu,otherwise it means a temp rerouting of the loop without the gpu and i would rather not do that
jtf2
than stop experimenting with the 1080.
lol
card was bought used which is why I want to just get it confirmed running properly
then I can block it and put it back in the loop
wife has hijacked my main pc so no more work on it tonight lol
JD
Toronto, ON
No settings in the BIOS to disable the PCIe slot entirely? I think if the motherboard senses anything in the top most slot (closest to CPU) that takes priority as the video output device. Since you don't have power cables attached, it's likely giving you that POST error code.
Don't have enough PCIe power cables to connect both? Have any molex-to-PCIe adapters? Use those on the 780.
I was in a similar situation a while ago, but my ROG board had DIP switches on it to disable PCIe slots. Super easy to disable the top GPU and test out my new one in the slot below before tearing apart my loop.
jtf2
typing with the 1080 up and running.
i have a seasonic 850 prime psu,and i just used the stock psu cables
cant wait to get this under water
thanks again for all the help
