new mb
KaptCrunch
Ontario
wolf does the cpu match the bios
look on MB box for bios version usually has a sticker then go to MB site and check CPU COMPATIBILITY for your MB
SEEN THIS BEFORE NEED TO DOWN GRADE CPU TO FLASH BIOS THAT SUPPORTS YOUR CHIP
WolfBane
new bruinswick
ITS AN 1151 CHIP 6700K SAYS THE MB SUPPORTS IT
ZZLEE
KANATA
You can remote that board or flash without a chip with tools in bios.
Groove
Ottawa(ish)
That board should be compatible with the 6700K right out of the box.
Since you had the same error code on the Z170 board as well it sounds like you have a dead CPU.
KaptCrunch
Ontario
Core i7-6700K (4.0GHz, 4C, HT, L3:8M, GT2, 91W, rev.R0) with bios 0604
looks need Rev.R0 check your cpu box
