New NVidia Driver update Power issue
Dwayne
Courtenay, BC
So, last night I noticed my CPU temps were really high. I fiddled with some settings but it was late so I thought I would check into it this morning. I checked my processes and found a thing called NVRLA running and using about 9% CPU cycles. Seems like if you ask about it on the NVidia subreddit page the questions get deleted. I posted one and will check and see if they cancelled it, but I did find this posting in another subreddit.
https://www.reddit.com/r/pcmasterrace/comments/o5rwwz
So, if you installed the updated drivers, have a look and see what your system is doing. The CPU temps might be high because this is running.
crazyea
Surrey, BC
I looked and I don't have that. RTX 3070. But I also don't install the game experience thing either.
EDIT: My comprehension is bad. I'm still on 466.77.
Dwayne
Courtenay, BC
I wonder if it is tied to that as I did install the Experience thing. Guess that comes out now.
Izerous
Folding Team
Edmonton
What I want to say is 9% load increased your temperatures pfft...
But there is no legitimate reason a driver utility should be that much of a pig causing that kind of load either way.
sweetb...
New member
I had the same issues with this running process, it came with the latest nvidia driver update.
I think i can´t post the link to nvidia to show what it is but if you want to know google NVIDIA GeForce FrameView-App.
Solution:
Go into Apps and remove it, it is not needed.
Enjoy the silence and lower temperatures.
Greets
Sweetb...
Dwayne
Courtenay, BC
I uninstalled GeForce Experience and rebooted, the application was still running on boot. So I downloaded just the desktop drivers and DDU. I disconnected my LAN, cleaned out NVidia stuff with DDU, rebooted without the LAN to install just the drivers. No more application running. Pain in the arse when NVidia drops in an app like that. No one should have to do the 3 finger salute to find a power virus running in the background, especially when they don't tell you what it is doing.
