iamjoeybro
New member
- Joined
- Oct 2, 2020
- Messages
- 1
I’ve been recently wanting a PC and now I’m thinking of getting one. I need advice on which components I should be getting for a PC. The PC needs good performance and have decent graphics. These are the components I have so far.
-AMD Ryzen 5 2600 CPU
-MSI ProSeries AMD A320 Motherboard
-Thermaltake Versa H18 Casing
-AMD RX 5700 XT GPU
-Silicon Power 512GB SSD
-TEAMGROUP T-Force Vulcan Z RAM
-Thermaltake Smart 430W
Is there anything I should be concerned about, such as compatibility with components with each other? Is there any component I should swap out for the best performance? Any advice will be appreciated.
-AMD RX 5700 XT GPU
