New rig... good enough for 8800gts?
creat3d22
New member
Montreal-ish, QC
Hi,
This week I'll be buying a new computer. I'm wondering how well an 8800gts would work on it... (especially PSU-wise)
Asus P5L-MX Green 945G motherboard
ThermalTake TR2 550W Power Supply
Pentium4-631 3ghz
2x Kingston 1gb ddr2 667mhz ram
400gb Seagate HDD
XFX GeForce 8800 GTS Extreme - 640mb
Any tips/comments gladly appreciated!
Rick
Gamashinoch
Ontario
Hi,
Pentium4-631 3ghz
400gb Seagate HDD
Rick
any of that stuff parts you're moving over to a new box? say the motherboard/cpu?
and e21XX series dual core Core 2 can be had for $20 more than that P4 based dual core. And run cooler.
An lga775 motherboard can be had for under $100 too.
Ran out of time to compare them to the price of the board you listed
b1lk1
Lindsay, Ontario
Definitely DO NOT get a Pentium 4 processor. Even the E2140 will stomp it soundly into the ground. A GTS 640MB card would be wasted in a machine like that since it would be horribly CPU bottlenecked. Get a 320MB GTS and a better CPU and mobo. Also, don't get a 945 chipset, get atleast a 965P chipset board.
3.0charlie
Laval, QC
Any specific reason why you chose those parts? I mean, that's an old single core P4, with a motherboard that has on-board video, when you want that GTS. Also that GTS could be bottlenecked by the P4 lack of performance.
What's your budget and what are you planning to do with that new rig?
John
JD
Toronto, ON
Well, definately no-go with a 8800GTS in that setup.
You need to get a new CPU, motherboard, PSU, probably RAM first.
creat3d22
New member
Montreal-ish, QC
updated...
Thanks for the tips... Well the primary reasons for my choices are budget and what I thought to be "good enough". Although I'm aware that you get what you pay for, some compromises had to be made...
This rig will primarily be used for 3d animation (3ds max) and some gaming (including Oblivion).
I've changed the components to the following... also, what's wrong with 2gigs of ram?
-Intel Core2Duo e6600 2.40ghz
-Asus P5B-VM SE 965G PCI motherboard
-650W Antec True650 Trio PSU
-Kingston HyperX 800mhz no-ecc 2gb RAM
-XFX 8800gts 640mb
-400gb Seagate HDD
Thank you,
Rick
b1lk1
Lindsay, Ontario
You really need to avoid motherboards with onboard graphics. The chipsets tend to run hotter and if you even plan on overclocking the system then you will not get nearly as much of an OC. Also, for the same price as a E6600, you could get a Xeon 3210 (Quad core) and have a more futureproof machine. A Quad core would also benefit 3D stuff (not games but your other plan).
Where are you shopping? What is your budget? These 2 pieces of info will help us help you the best.
creat3d22
New member
Montreal-ish, QC
My budget is 1200$ maximum, buying from MicroBytes Montreal Computer Ordinateur (good prices and they've got a store right next door) except for the 8800gts which I'm getting from TigerDirect.ca - Computer Parts, PC Components, Computers & Electronics .
#27090 INTEL CORE 2 DUO E6750 2.66G/1333/4M/S775 225$
#24038 650W POWER ATX ANTEC TRUE650 TRIO 129$
#24779 SATA2 400.0 SEAGATE 7200 16M ST3400620AS 105$
#22635 CASE ATX ALPHA 602BK BLACK NOPS 35$
#27313 S775 GIGA GA-P35-DS3L P35 PCIE 115$
#25810 KINGSTON HYPERX 800MHZ DDR2 NO-ECC 2048MB LL 145$
This is the final list so far...
BALISTX
Ottawa, ON
Personally for $1200 this is what I would get if I was getting it this week.
Intel Core 2 Duo E6750 Dual Core Processor LGA775 Conroe 2.66GHZ 1333FSB 4MB Retail - $208.98
(Receive a FREE copy of Sword of the New World)
http://www.ncix.com/products/index.php?sku=25298&vpn=BX80557E6750&manufacture=Intel&promoid=1019
Thermalright ULTRA-120 Extreme 6 Heatpipe Cooler LGA775 Heatsink *Fan Not Included* - $46.99
http://www.ncix.com/products/index.php?sku=23531&promoid=1083&quantity=1
Scythe S-FLEX SFF21F 120MM Cooling Fan 1600RPM 28.0DBA 63.7CFM FDB - $14.99
http://www.ncix.com/products/index.php?sku=17749&vpn=SFF21F&manufacture=Scythe
Gigabyte GA-P35-DS3L ATX LGA775 P35 1333FSB 1PCI-E16 3PCI-E1 3PCI SATA2 Sound GBLAN Motherboard - $97.99
http://www.ncix.com/products/index.php?sku=25369&vpn=GA-P35-DS3L&manufacture=Gigabyte&promoid=1019
Mushkin HP PC2-6400 HP2-6400 2GB 2X1GB DDR2-800 CL4-4-4-12 240PIN DIMM Dual Channel Memory Kit - $84.99 (MIR $69.99)
http://www.ncix.com/products/index.php?sku=26064&vpn=996576&manufacture=MUSHKIN&promoid=1019
Western Digital SE16 320GB SATA2 7200RPM 16MB 8.9MS Hard Drive OEM 3 Year MFR Warranty - $76.99
http://www.ncix.com/products/index....AAKS&manufacture=Western Digital&promoid=1019
Corsair CMPSU-620HX 620W ATX Triple 12V 50A 24PIN ATX Modular Power Supply 120MM Fan 2X PCI-E - $148.99 (MIR $118.99)
http://www.ncix.com/products/index.php?sku=19831&vpn=CMPSU-620HX&manufacture=CORSAIR&promoid=1019
XFX GeForce 8800GTS XXX 580MHZ 320MB 1.8GHZ GDDR3 PCI-E Dual DVI-I HDTV HDCP DIRECTX10 Video Card - $299.99 (MIR $279.99)
Includes FREE game: Ghost Recon Advanced Warfighter (while supplies last)
http://www.ncix.com/products/index.php?sku=22629&vpn=PVT80GGHD4&manufacture=XFX&promoid=1019
Antec Nine Hundred Mid Tower Gamer Case 900 ATX 9 Drive Bay No PS Top USB2.0 1394 Audio - $109.98
http://www.ncix.com/products/index.php?sku=21123&vpn=NINE HUNDRED&manufacture=ANTEC&promoid=1019
Shipping & Handling: $57.63
Shipping Insurance: $29.76
Subtotal: $1,079.29
GST(6%): $64.76
YOUR TOTAL: $1,144.05
