New Router; Computer Connection Issues
Mr. Gruntsworthy
Courtice, ONT
My 5 year old router recently kicked the bucket, so I recently replaced it with a newer model. Both are D-Link 10/100 wired routers.
Back when i was trying to figure out what was messed up, one of my suspects was the internet. I ended up uninstalling the driver for my network port; but i reinstalled it again afterwards.
As it stands now, when i'm on the internet, Windows Live Messenger seems to keep having connection issues. It tells me that there's some sort of connection issues sometimes; saying that any changes made to it on my computer won't be transferred to other computers i'm signed in on. That in itself doesn't mean much, but the connection issue behind it does.
As well, when i'm trying to surf, loading webpages is painstakingly slow; it's like if you're running Bitcomet with like ten downloads, except bitcomet's not running. (bitcomet is a torrent program for those of you who don't know). Sometimes, the pages don't even load, and i have to re-try them.
All LAN traffic seems to function smoothly; my Xbox can pull videos and music from my main rig with no problems.
Should I maybe try reinstalling my motherboard drivers from the original CD, and/or try running Windows Update?
Help me diagnose this issue, my computer is crying :( i may just end up saying f*** it and buying a PCI network card. :p
Off the top of my head i can't think of anything else to help; im kind of tired, lol. If i'm missing a crucial piece of information, don't hesitate to throw stones at me :p
chouchou
Vancouver
Did this problem start right whne you got your new router?
Also, have you checked in regards to firewall problems? Setup the router correctly? (all settings correct?)
What model is your router? You wifi/lan? There's a lot of variables when dealing with connection issues :S
Good luck!
Arinoth
Halifax
Have you tried releasing and renewing the IP address of your computer, it could be stuck to the old one, confusing this new router, or conflicting with another device causing it to drop sometimes and make it look like you barely have net connection.
sswilson
Moncton NB
Did you do a full power cycle when you got the new router? Pull the power plug out of both the router and the modem. Leave them off for 1 minute, then bring just the modem back up. Once the modem has a proper light pattern, plug the router back in.
If everything is working well on your inside network it sounds like an issue between your modem and your router. Have you tried plugging one of your computers directly to the modem to see if the issue goes away? (You might have to power cycle the modem when you change the device that's plugged into it).
subliminal
Vancouver
Does it have the same problem if you plug your computer directly into the modem without the router?
Mr. Gruntsworthy
Courtice, ONT
Before i replaced my modem, i was connected directly to it after my router had died.
like i said, it's a wired d link router, a newer model than my old one.
how would i go about releasing my IP address? im on windows vista, btw.
and yes, the first thing i did was do a full power cycle to make sure my router and modem were synced together.
Mr. Gruntsworthy
Courtice, ONT
I reset Windows Firewall back to the defaults, and it seems to have solved the problem.
edit: never mind, it didn't...
Arinoth
Halifax
Ok, to release your ip:
Go to Start Menu
in the little search bar thingy with vista/win 7 or run with xp type in cmd
a black dos like window will come up with a command prompt c:\(it most likely have whatever the user name you have set to following it), type in ipconfig \release (or \release all)
then, type in the next prompt, ipconfig \renew
Hopefully this helped you
Frank Encruncher
Edmonton,Alberta
Frickin' Vista
Same problem, router wouldn't connect to the internet
I just go it to work
Try this
Open Network and Sharing
Click on Customize Network
Should open Set Network Location
click on Merge or delete locations at the bottom
Delete all the networks
Then restart everthing
Windows should ask to create a new network when boots
Hope this works for you
Mr. Gruntsworthy
Courtice, ONT
when i try to release my ip, it says 'this operation requires elevation.' what does that mean? :/
and Windows Firewall does seem to be hindering my internet a bit, though with Windows Firewall off, my internet still isn't at 100% of what it should be.
