Newbie Hard Line Cooling Question
Interesting approach to supporting the tubbing. It is one of the reasons why i hand bent everything when I did the one hardline loop. The tubes can safely hole themselves up but not half a dozen fittings comfortably. Wth that amount of tubing it would have taken a long time to bend it all though.
Are the supports stubs of copper tubing?
Thanks. Yeah the hard line was definitely fun. Now I just have to figure out why I can't get into BIOS. I'll post about it, maybe can get some help.
What Motherboard do you have ?
The support are just some copper tube nubs...l
-Motherboard...x670 Aorus Elite Ax
-CPU...AMD Ryzen 7 7800x3D
-Video Card....Zotag Gaming GeForce RTX4080 16GB Amp Extreme
-Memory...64GB T-Force Delta DDR5
-Tower...Thernatake P90
-JellyFIsh Tank
-Plasma Light
-Russian Nixie Tubes (Time & Date)
-Power Supply- ROG Loki 1000W Platinum
I found this. Not the exact same but should help.
Edit: push shift and restart and it will get into low level stuff. A new hack I did not know. :)
