News from InWin The 707 and 703
c3p0
Active member
Land of Noctua, Austria
Well seems InWin did it again.
These shots speaking for themselfs
707
E-ATX, ATX, M-ATX, Mini-ITX
Fan mountings:
2x 140/120 mm Front
1x 140/120 mm Back
1x 140/120 mm Behind Cpu :shok:
1x 140/120 mm Hdd tray mount
3x 120 mm Top
2x 140/120 mm Bottom
Coming at a pricepoint of 100€
Must have. My god the beauty, the feels
703
Fan mountings
2x 120 mm Front
1x 120 mm Back
1x 120 mm Bottom
Unfortunate no top fan options :/
Pricepoint of 60€
Good job inwin. These are 2 amazing cases :)
Bond007
Nova Scotia
They look pretty sharp, but man did they forget about airflow through the drive cage....They must have tried to block it that much. Otherwise it seems well laid out. 703 should use the rubber grommets like the 707.
c3p0
Active member
Seems the top hdd tray is removeable on the 707. Dunno about the lower tray. No grommets are ok at that pricepoint. As they fall out all the time when not done properly. I can resemble from a Phantom 410 where these popped out all the time while routing cables. Ended up removing them as it was so annoying.
