Want to Sell Nikon D7100 W/18-140mm F3.5-5.6 & 50mm F1.8 (Delta, BC)
Black_Ice-Dragon
Lower Mainland, BC
All items are shipped from Delta, BC. If your local I don't mind driving a bit.
Nikon D7100 W/18-140mm F3.5-5.6 & 50mm F1.8 & extra battery $600 shipped
  • Used as my main camera the last couple years. Really hasn't seen as much use as I would like lately. In almost perfect condition.
  • Missing the original boxes as I did not have enough room when I moved so they are in storage in another provice. I can get them if someone really wants them.
Sold:
EK-XRES 140 Revo D5 RGB PWM w/140mm fan mount bracket
EK-HDC Fitting 16mm G1/4 – Nickel
EKWB EK-FB ASUS X399 Gaming RGB Monoblock
Asus EATX X399 Zenith Extreme
AMD Threadripper 1950x
Corsair 900D Case
Corsair DDR4 3000 2x8GB Kit
EVGA 1080 Ti Hybrid
Gigabyte X99 Phoenix SLi Motherboard & 5960X CPU
Dell R710
EVGA Hybrid 1080Ti SC2
Gigabyte Aorus 1080 Ti Xtreme
Ryzen 1600 CPU
Gigabyte AORUS GA-AX370-Gaming K5 AMD Ryzen AM4 X370
Dell Powerconnect 5548 Switch
Samsung Gear Icon X Bluetooth Headphones
Noctua NH-U9S
On2wheels
613 Ontario
That 1080ti with the custom fan, did you have to remove the heatsink to install the fan? What difference did you see with the new fan?
Lysrin
Nova Scotia
I'll chime in here, the fan change was on the rad, not the cooling shroud so no impact on the heatsink. You can see the Corsair fan in the pics with the red ring.
As to the difference with the new fan, Black_Ice-Dragon would have to comment on that.
That is a very nice 1080Ti model IMO... GLWS!
Black_Ice-Dragon
Lower Mainland, BC
Thanks for that. I was just going to clarify that. I found the fan practically silent after replacing it. The stock EVGA one i found quite loud. The new corsair one also seems to have dropped the temps slightly. Im also doing the same thing with my main PC FTW3 Hybrid and the gpu even under 100% load never gets over 43C.
vanasfield
New member
Are there any markings on the Hybrid shroud or is it just dust or something?
Thanks,
Mike
