No display on my new build
CactusJoe
Hello, i need help plz ;(
I just put on together every part of my new cpu and... i got no display. Nothing comes out of the display port on the Mobo or on the GPU. i tried a few things like moving the ram sticks around and such but im starting to think i have a bad part....
Is there something i should check before RMA?
CPU - Intel - Core i7-9700K 3.6GHz 8-Core Processor
CPU - Cooler Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard - MSI gaming plus Z370
Memory - G.Skill - Aegis 16GB (2 x 8GB) DDR4-3200
Storage - Samsung - 970 Evo 500GB M.2-2280 Solid State Drive
Video Card - Asus - GeForce RTX 2080 8GB ROG Strix Gaming OC Video Card
Case - Fractal Design - Meshify C ATX Mid Tower Case
Power Supply - EVGA - SuperNOVA G1+ 650W Fully-Modular
Monitor - Asus - ROG SWIFT PG278QR 27.0" 2560x1440 165Hz Monitor
Let me know if this isnt the right place ill delete post tyyyy
sswilson
Moncton NB
Moved to troubleshooting.
Did you try with an hdmi cable to your TV?
Any lights on the board? (I really wish boards still came with speakers for post error codes.... :\ )
CactusJoe
ty
I tried with hdmi and vga cable to an old monitor but it still says no input detected
sswilson
Moncton NB
Any lights or fans coming on?
Did you try a cmos reset? Does the debug led have any kind of indication on it?
edit: Does the power supply fan come on?
CactusJoe
mobo is lighting up fans are working
psu fan is working aswell
the debug light is on and red at boot and stays on
bad cpu?? i dont know much about that debug thing...
sswilson
Moncton NB
Looks like there are 4 lights... which one is lit going from the top down?
If it's the first one it would indicate an issue with the CPU.
sswilson
Moncton NB
Ummmmmm.......
Unless there's been a bios update, it doesn't look like that motherboard is compatible with the processor you've chosen.
CactusJoe
second light is for ram from the manual
switched around a stick now it dosnt light up so no more debug light
i still dont have display tho ;_((((
CactusJoe
Holy smokes i think i found it
9th gen are compatible with z370 but they need a bios update
now the question is...
how do i update a mobo bios without display
