No Image on monitor
Phobia
Richmond, BC
Hello everyone,
My computer won't show any image on the monitor. I have tried two different monitors and just tried a different graphics card today. When you press the power button everything turns on, and my monitor recognizes there is a signal coming to it, but just stays blank. Would that be my motherboard that's dead?
If that is the case, I have two ocz vertex in raid 0.. Is there any way to get some data off of them, or am I hooped?
Thanks
wirerogue
Hello everyone,
Thanks
i know this wont make much sense but, try reseating your ram.
ram that is not properly seated will cause you to lose all video display.
if that doesn't work, it could be bad ram as well.
mello_newf
Active member
Ontario, Canada
Few things I always try
Check the ram (remove all but 1 stick and rotate)
Remove video card and try onboard if you have it
Try using another PCI slot if you have one
Clear the coms (remove mobo battery and press power repetitively)
Remove usb/lights/hdd (anything that you don't need to get into bios)
Check that all cables are tight
If you try all that then it's most likely the mobo I very rarely see the CPU go
ZZLEE
KANATA
System spec what we talking about ??
Does it have on chip vidio ??
Phobia
Richmond, BC
Thank you for the replies.
I have an Asus P5e, intel qx9650, corsair dominator ddr2. I have tried a few different video cards, switching my ram around, clearing the CMOS every time I made significant changes.
ZZLEE
KANATA
Check KIJIJI or the like fore a 775 board.
I foresee upgrades in your feuter. :whistle:
Phobia
Richmond, BC
Thats what I thought. Is there any way to get the data off of my raided harddrives? I just have a few files that I would like, but am pretty certain I won't be able to get them.
