"No Signal" flashes before Win7 load screen
BukitHedd
Dartmouth, Nova Scotia
Heres my system I built last week.
2600k.
Asus P8Z68-vPro Gen3
8gbs Corsair Vengeance low profile ram.
No video card yet.
OCZ Vertex 3 120gb boot drive and a Hitachi 2tb hdd.
Windows 7 Home.
Here's my problem, although I'm not sure its a problem.
I just started to overclock a bit, but I'm not feeling confident about it so I reset everything back to what I think it was before I started.
I notice now that when the computer boots, I get the Windows Loading screen, then the monitor goes blank, says "No Signal", and my keyboard backlighting turns off for a split second. Within a couple seconds I see the login screen. This whole event only takes 2-3 seconds. No hiccups during normal use.
I'm just wondering if its somewhat normal. It may have been doing it all along and I've never noticed.
I'm going to reset my CMOS because I want it all at default settings for now until I research overclocking more.
Thanks.
KaptCrunch
Ontario
possible in cmos settings for video
has video boot order looking in slot video for first boot , moniter then No Signal
don't see it then moves to onboard video, then you got screen
