no vidio after crash!!
ebcogs
Member
Hello and thank any and all who can help me:thumb:
I was just playing rfactor and my computer locked up, i had to manualy hard boot my machine but when the system starts post there is no vidio signal and my monitor says that the vidio cable is not attached,
I can hear windows load from listning to opining sound it make but still no vidio!:sad: if i push the power off switch i can hear the system shut down and power off,
What up did i just blow my $400.00 MOBO.:shok:
I have put both cards in another mobo and thay work fine.
can someone help me please:biggrin:
ebcogs
Member
Thank you very much, the asus mobo has a very nice clr cmos button on it and i tryed pressing it several times to no avail,
I have also tryed both cards one at a time with the same results no vidio signal.
only thing that changed in the computer was that about one hour befor the crash i had just installed CCC 9.9 and it was working fine up untill the crash.
martin_metal_88
Quebec City
First, welcome to HWC. It can be 2 things. first, mobo. Second PSU cannot handle both card anymore. First, try to clear Cmos, then try change PSU if it does nothing. I`m sorry.
Ask for more.
ebcogs
Member
Thank you martin metal 88,
I have another psu at my friends house that i can use to test, I also removed the battery from cmos and still no vido.
i will post back later and tell if the psu fixed or not. THanks to all who help.
KaptCrunch
Ontario
sounds to me that your crossfire is looking at 2 moniters .....reason no video cause your moniter is configured for secondary......need to hook another moniter and setup primary
Note: the most closest video output to the back panel header is usally is the primary port
ebcogs
Member
I will try that also, will it mater if one is vga and other dvi?
martin_metal_88
Quebec City
This basically have no sens. At the mobo post cross-fire is still disabled the the moment driver come in at windows start.
Ask for more.
