Noctua U14S not compatible with MSI Z87 G45?
Messerschmitt
Active member
So after installing the U14S, the fan is touching the 1st RAM heatsink. Isn't the U14S suppose to be compatible? Am I doing something wrong? If I try to squeeze the ram, it is visibly pushed (the space between the 1st and 2nd is smaller than the space between 2-3-4th ram)
imgur: the simple image sharer
If I move the fan upwards so that the fan is just above the DIMM, it sticks way to much and cannot close the case. As is, it barely has clearance for the side pannel
crowTrobot
Scarborough, Ontario
EDIT: Made a typo, typed 5mm instead of 1.5mm
Yeah not on MSI boards. I have no idea why Noctua marked it as compatible on their site. Most
motherboards leave an additional ~1.5mm gap between the CPU socket and the first DIMM slot for clearance, for example this ASUS Z87 Gene:
Combined with thicker RAM heatspreaders and the fact that MSI boards have the "standard" distance with the DIMM slot and the CPU, it won't fit, or if it does it will be pushing against it like your setup: (Dominator Platinum on MSI Z87 MPOWER MAX)
