After doing some research about the Barrow pump + radiator, it seems to be not a good idea as it seems impossible to service with it in the tower. Also, I seem to missed the boat on the Rajintek cooler since Newegg is sold out and may not restock (it's for 1080TI so they may not make it anymore). So I found Formulamod website and the price seem cheap enough but before I commit, I got some questions.
- Are the screw hole spacing on DDC pumps standardized? I want to mount the res on the bottom of my case where there is a 120 / 140 fan intake
- Do I have to buy plugs separately?
- Any recommended online shop?
- How exactly do I control the speed of the pump automatically? I'm just cooling the GPU and I know the header can control the fans but not sure how to hook up the pump so the GPU controls it
- Any difference in hose ID size and impact on performance? My gut say smaller ID means higher pressure?
- Copper rad to match the EK water block (it's copper)
- Soft hose
- G 1/4 plugs and barbs
- 3 way T-splitter + ball valve for easy draining or just the ball valve if there is multiple outlets
- Res with pump + bracket
- Pressure tester and filling bottle
- Flushing agent + cleaning agent
- Distilled water + dye (so I can see the thing flushed not for looks)
- Spray bottle for leak test (water + dish soap)
