NVidia Ampere rumors
Dwayne
Courtenay, BC
An unknown NVidia GPU on the charts. 3D Timespy graphics score of 18257. Stock 2080 Ti is 13939.
Almost as fast as a Kingpin OC'ed EVGA XC 2080 Ti running at 2385 MHz with 2170 MHz mem - 18664.
Also some leaked specs, all rumours, of course.
RTX Titan (Ampere)
RTX 3090
/3080 Ti
RTX 3080Titan RTX (Turing)RTX 2080 TiRTX 2080 SuperRTX 2080
GPUGA102-400GA102-300GA102-200TU102-400TU102-300TU104-450TU104-400
CUDA Cores5376524843524652435230722944
Memory24GB GDDR6X12GB GDDR6X10GB GDDR6X24GB GDDR611GB GDDR68GB GDDR68GB GDDR6
Memory Speed17Gbps21Gbps19Gbps14Gbps16Gbps15.5 Gbps14 Gbps
Memory Bus384-bit384-bit320-bit384-bit352-bit256-bit256-bit
Memory Bandwidth816GB/s1008GB/s760 GB/s672 GB/s616 GB/s496 GB/s448GB/s
rjbarker
Courtenay, B.C
Its what Ive been holding out for ......I'll replace 2 1080Ti's for a single 3080Ti .......hope pricing is at least the same as 2080Ti....
belgolas
St. Thomas, Ontario
There are several issues with that chart. First off the 2080 Ti has 11gb of ram not 24gb. Also 352bit not 384. It has 4352 cores not 4652.
Take all these leaks with a big fat grain of salt. I can see the GPU coolers being legit as it would take a lot of effort to fake that and even Nvidia responded to them but benchmarks at this stage is something I wouldn't take reliably. Though 30% increase for the top end doesn't seem out of line with previous generation leaps. Seems about a below average increase in performance.
Gman109
I agree regarding WCCF tech leaks, but they've been close enough in the past on some of their rumors, and I also think that 30% isn't a huge inscreas, when the 1080 came out everyone lost their minds over the increase. Every Youtuber that had a tech channel over 20k subs was invited out by YT, it was insane the attention it drew. Then the 2080 series was much more subdued. I wonder if the 3080 will result in the same sort of fanfare due to its level of performance increase, I'll be real happy if the 3080ti/3090 are 30% faster than my 2080tis, but I sure would like to see it pushing 40% or even higher.
