Nvidia Double Monitor Woes
jcmaz
Vancouver, BC
Hey HWC,
I can't seem to set the resolution for my 22" lcd monitor and my 1080P lcd Tv properly. The Nvidia control panel won't let me set different resolutions. What should i do now?
Btw, does anyone know how to use this little wire thing for audio from DVI-HDMI cable?
THX for ur help
jcmaz
Vancouver, BC
Thank you, now i just need to send sound thru the HDMI to the tv. I have the SPDIF wire but i can't seem to find the header on my soundcard nor does the other end seem to fit on the 9600GT.
mo' power
Scarborough
I believe your choice of spdif out on that card are either optical cable (toslink) or coaxial cable (rca). What kind of sound system are you using for that card?
jcmaz
Vancouver, BC
I currently have a Logitech X240 linked up w/ the soundcard by 3.5mm jack but i want to output the sound thru the HDMI to my tv which i cannot do rite now.
