Temperatures & Acoustics / Power Consumptions
For all temperature testing, the cards were placed on an open test bench with a single 120mm 1200RPM fan placed ~8” away from the heatsink. The ambient temperature was kept at a constant 22°C (+/- 0.5°C). If the ambient temperatures rose above 23°C at any time throughout the test, all benchmarking was stopped..
For Idle tests, we let the system idle at the Windows 7 desktop for 15 minutes and recorded the peak temperature.
Unfortunately, this test doesn't really reflect reality since NVIDIA's GTX 770 will be primarily a custom-designed card from board partners. These results meanwhile were achieved using the so-called "stock" heatsink which won't be making it onto most final retail units.
With that being said, actual temperatures achieve should be even better than these which bodes well for Boost clocks.
What you see below are the baseline idle dB(A) results attained for a relatively quiet open-case system (specs are in the Methodology section) sans GPU along with the attained results for each individual card in idle and load scenarios. The meter we use has been calibrated and is placed at seated ear-level exactly 12” away from the GPU’s fan. For the load scenarios, a loop of Unigine Valley is used in order to generate a constant load on the GPU(s) over the course of 15 minutes.
As with the temperature results, we expect to see an improvement in acoustical performance in retail cards. Nonetheless, the GTX 770 is the quietest card in these charts, even without a custom heatsink powering it along.
For this test we hooked up our power supply to a UPM power meter that will log the power consumption of the whole system twice every second. In order to stress the GPU as much as possible we used 15 minutes of Unigine Valley running on a loop while letting the card sit at a stable Windows desktop for 15 minutes to determine the peak idle power consumption.
Please note that after extensive testing, we have found that simply plugging in a power meter to a wall outlet or UPS will NOT give you accurate power consumption numbers due to slight changes in the input voltage. Thus we use a Tripp-Lite 1800W line conditioner between the 120V outlet and the power meter.
Power Consumption on enthusiast graphics cards is a heavily debated point, with many gamers casting a blind eye to it in favor of the best possible performance. With Kepler, NVIDIA has managed to bring efficiency up to a point where they can offer the best of both worlds without sacrificing in either area.
The GTX 770 does post some impressive numbers here, easily besting the HD 7970 GHz Edition. However, the addition of faster core speeds and ultra high performance 7Gbps GDDR5 seems to have added a bit to its power needs. This shouldn't be a concern though.
Temperature Analysis
Acoustical Testing
System Power Consumption
