Old/New build for my daughter - PS big enough?
great_big_abyss
Winnipeg
Given the imminent upgrade of my main rig, I'm planning on repurposing my old parts to build a basic gaming rig for my nine year old daughter. She's currently gaming on an old HP Elitebook with a 3rd gen core i5 processor (mobile) and some low tier Radeon graphics chip. She mostly plays Roblox, and has recently started playing Sims 4. While her laptop is capable of running Sims4, I can tell that it's working very, very hard, and is barely keeping up. I feel like an i7 3770K, even running on IGP, will be a bit of an upgrade for her, and should run much cooler and quieter than the current laptop that sounds like a turbine and gets very, very hot.
We will start out using the 3770K's IGP at first, but the plan is to eventually find a low end, efficient video card to throw in there. Something like a GTX960 or GTX1650, or an RX570, something of that ilk. I've got a collection of SSD's in my current rig that will be rendered obsolete by the 1TB NVME drive that I'm getting, so I'll be able to re-use at least one of them in this rig, if not all of them.
I think the idea will be to gift her the parts for XMAS, and then together we can build her PC - I can introduce her to the basics of assembling all the components, installing windows, etc. I need to do this on an extreme budget, however, spending as little money as possible.
The parts list will look as such:
Parts I already own:
Intel Core i7 3770K (running at stock clocks)
MSI Z77A-G45
Corsair Vengeance 1600Mhz 2x8GB
WD Blue 500GB SATA SSD boot drive
Zalman FX70 fanless passive CPU cooler (I used this on the 3770K for a couple of years, and it works great - 80W limit, perfect for the 77W TDP of a stock clocked 3770K)
Parts I need to buy:
Case - Fractal Design Focus G ATX Case - $54.99 at Memory Express - https://www.memoryexpress.com/Products/MX70610
Power Supply - EVGA 450 BR - on sale for $29.99 at Amazon - https://www.amazon.ca/EVGA-100-BR-0...Corsair|EVGA&rnid=7590290011&s=pc&sr=1-1&th=1
Question, will the 450W Powersupply be enough to power a stock clocked i7 3770K, one SSD, and eventually a small, lower power graphics card? My thinking is YES, but I want to make sure before ordering it.
ALSO, she (or I, probably I, on my new rig) will need a new Windows 10 Pro key. Where is the best place to buy one of those?
Will the 450w be enough...yes it should be fine for what you have mentioned, and it will probably not cause any issues. That said, I expect it is a poor performing unit, so I wouldn't put a ton of faith into it long term.
If you wanted something a bit beefier and efficient that could potentially last a few build updates, Seasonic Focus Gold (Seasonic GM) 550w have been around $60 quite a few times. The extra 100w, better build quality, and gold rating make it easily worth the extra $ if you are going to keep it for a while. Unfortunately it is a bit more right now (cheapest looks like $62+shipping), but if you don't need it right now you could see what sales happen for BF.
Well, this build is gaining a momentum of its own.
I found a Corsair CX550 powersupply on Kijiji for $40. I offered $30, which was accepted. Then the person selling the PS asked if I was interested in a GTX1060 6GB which they have listed for $400. We settled on $380 for both the CX550 and the MSI GTX1060 6GB
SO, my daughter's build will look as such:
Intel i7 3770K (stock clocked, cooled with a Zalman FX70 passive air cooler)
MSI Z77A-G45
2x8GB Corsair Vengeance 1600Mhz DDR3
2x 128GB Crucial M4 Sata SSD's in RAID0 (boot drive)
500GB WD Blue Sata SSD (game/media drive)
MSI GTX1060 6GB
Corsair CX550 PS
Fractal Design Focus G ATX Case (W/Window) in White
Not such a bad build for a nine year old. It should run cool and quiet, and do everything that she needs it to well into teenagehood. Best part is, I'll wrap all the individual parts and put them under the tree, and then I can teach her how to build a PC.
Currently she's using a relative ancient HP Elitebook 8470P with an i5 3320M and a Radeon HD7570M 1GB. It works really, really hard to drive the games (poorly - playing Sims 4 is almost a slideshow) she wants to play, so this new rig will be a meaningful upgrade.
Well, this rig is built and done, good to go.
Sum up the specs:
Intel i7 3770K (stock clocks)
MSI Z77A-G45A Motherboard
Zalman FX70 Passive Cooler
2x8GB Corsair Vengeance 1600Mhz DDR3 RAM
MSI GTX 1060
Corsair MX500 Boot/game Drive
2x WD GREEN 2TB HDD's in a spanned volume for media
Corsair CX550 PowerSupply
Fractal Design Focus G (white) case
ACER 24" 1920x1080P Display
My daughter helped me build it yesterday. I think that for the games a nine year old girl wants to play, this rig should have PLENTY of staying power for the next few years.
Already it's a MASSIVE upgrade over her old 3rd gen Intel HP Elitebook which was running very sluggishly.
Has to be, to be able to cool an 80W chip completely passively.
Although in truth, it's not completely passive, as there is airflow through the case, from front to back.
Yeah, I noticed the rear fan in the last pic is relatively close to the heatsink. That alone would be drawing some air through the fins.
Nice build.
