Older Machine Running Windows XP - Issues
trayton
Tillsonburg, Ontario
I am working on a friends HP desktop machine (AMD X2 5000+) so its an older one.
I can do the factory restore easy enough (using F10) and its nice and fresh (minus all the crap it installs games, trail of office, trial of norton etc)
It comes with IE6 so it can't do windows update
I downloaded both SP2 and SP3
Doesn't matter which one I do it installs says to reboot and then it just does a constant loop of reboot and won't go back into windows (even using last known good).
I can get it into safe mode though but thats it. Any ideas?
Thanks!
I could understand if I was installing other drivers and things but I'm just installing windows SP2 (or SP3) nothing else.
Shadowmeph
try using a live linuxdistro or something like that to test the system like memory tests, stress tests
Johnny Buntu
Member
West Van
Thanks!
Yup, its a bug in BOTH the AMD chip and Microsoft, neither one ever got around to solving it.
1) make sure you get the latest Bios for the mobo
2) sometimes just installing a usb device will help stop the loop reboot
check this link
Fix for continuous reboot after installing Service Pack 3 in Windows XP
Get back to me
Cheers
KaptCrunch
Ontario
Thanks!
XP is dead this month
Best buy a OS upgrade to win8 or a new system with current OS
