on screen keyboard
Haiden
Active member
Newfoundland
hey, im having a problem with the on-screen keyboard on vista basic. It keeps starting on start up, not sure how to disable it.
tzetsin
AB
It didnt somehow get added to your "startup" folder in your start/programs menu did it?
grinder
start --> control panel --> ease of access center
select "use the computer without a mouse or keyboard"
make sure "Use On-Screen Keyboard" is not checked
that should do it
Haiden
Active member
Newfoundland
that should do it
nope, still commin up at start up. any other ideas?
tzetsin
AB
start/run MSCONFIG go to the "Startup" tab, uncheck EVERYTHING reboot, if it goes away check the things you want an hopefully the one that it is, is obvious enough to leave unchecked.
Haiden
Active member
Newfoundland
i did the system restore and its not listed in the msconfig.. still nothing, i dont understand...
any other ideas?
Lima
Laval, Qc
Just a quick question.
Did you install any drivers for a pen tablet like the Wacom Bamboo?
I just reinstalled mine and I am reminded of why I hate those drivers! They automatically turn on some Tablet PC function in Vista. I am going to have to look for a solution to this over at Wacom.
