Onkyo HT-S3200
aristhrottle
Toronto
I bought my aunt the HT-S5100 a while back and she loves it. The sound is amazing for the price and it's a lot more user friendly than my Denon at home (but I'm convinced that Denon is manufactured by aliens because of its unintuitive-ness).
The only hitch with the 5100 - and I'd imagine it would be the same for the 3200 - is that it only does video pass-through over HMDI. That is, you'll need to use another audio input (coax or optical) if you're using HMDI. Not really a big deal, but something to keep in mind.
Dr_BenD_over
Fallen Folder
Nova Scotia
Thanks for the reply. The pass through thing seems to be the only real fault I found on my search, and it's no biggy, I'd use the optical output from my TV anyway.
aristhrottle
Toronto
Hey did you end up getting this? I'm looking for a gift for Christmas and was wondering how it performed.
Dr_BenD_over
Fallen Folder
Nova Scotia
Not yet, it was going to be a Xmas present for myself, but I wound up buying a 5850, probably be a birthday present now.
H
HaDeS
Guest
bang for buck they make great recievers. Audio passes through just fine on mine if you configure it correctly.
