Opinions / improvements on this build?
Acrid
Member
CPU: Intel Core i7-9700K processor 3.6GHz Octa Core LGA1151 CPU
PSU: Corsair CP-9020133-EU TX-M series Part-modular cable management ATX PC power supply
Case:
Cooler Master MasterBox MB530P RGB
MOBO: MSI 7B18-001R MAG Z390 Tomahawk Motherboard Black
SSD: ADATA XPG SX8200 Pro 512 GB Solid State Drive, PCIe Gen3x4, M.2 2280
RAM: Corsair Vengeance RGB Pro Series Black, DDR4-3200, CL16 - 16 GB Dual Kit
HDD: Seagate BarraCuda Compute HDD, SATA 6G, 7200 U/min, 3,5 Inch - 2 TB
GPU: Gigabyte GeForce RTX 2060 Super Gaming OC 8G, 8192 MB GDDR6
Cooler: Enermax LiqFusion 240 RGB Complete Water Cooling - 240 mm
Extra: Thermal Grizzly Kryonaut Thermal Paste - 1gr
danmitch1
2648.30 CAD , If im not mistaken I believe you still have room in your budget with the current parts no? Could go for a 2070 or even 2080
Acrid
Member
I initially had a 2070 but came out overpriced as I also got a Monitor.
danmitch1
Oh ok, well the parts you picked are great. I wouldnt really change anything
Izerous
Edmonton
My only comment might be do you need 2TB of storage for anything. Might appreciate a second m.2 drive (assuming that board supports 2) over the extra storage depending on your use cases. Ie you might have 1TB steam library but honestly how much of them have you even run in the past year. probably not nearly that much and could be left un-installed.
Acrid
Member
I also have many songs (About 700gb) therefore i quite much need that. In the future i might try getting a second SSD.
Izerous
Edmonton
Offloading stuff like that to a small NAS is the future make life a bit easier if you can swing it. Very obviously not in the budget right now though.
