Overclocking Failed. Error message on bootup.
jaspap
Active member
Edmonton, Alberta
Well, after fixing the issue of random freezing, now, just starting today. Whenever I start up my system, it begins to start up, then shuts itself totally off, then starts up again. But then I get a error message stating that " overclocking has failed " Press F1 to enter BIOS. What the heck, I have never even attempted to overclock my system, what do I do now. I cleared the RTC, but that did nothing, why would this just happen all of the sudden.
Actually, last night when I shut down, Windows said it was updating 1 of 8 things, there has to be a connection right?:sad:
Asus P8P67 PRO-B3 revision
EVGA GeForce 560ti
Intel i5 2500k
Corsair Vengeance 8GB 1600 2x4
Win 7 home premium 64bit
Western Digital 1TB SATA3
Corsair 850TXV2
_dangtx_
mtl
you might want to play with the ram speeds and voltages a bit more. drop it to 1333 :)
could be anything. leave it on auto for now, or put it on manual
auto does a great jobbe,usually.
LarkStarr
if you've never overclocked, why do you have a K series Sandy Bridge CPU?
what is the BIOS reporting for your cpu speed, voltages, ram speed, timings and etc? screenshots would be good (with a camera, obv)
Soultribunal
Mississauga
I don't OC and I have had Extreme Editions and Black Editions. Doesn't mean anything mate, and suprisingly enough I have actually just enountered this problem as well on an AM3 build.
If I come up with anything I'll let you know,
ASUS board as well,
ST
LarkStarr
your CPU is idling quite warm.. are you using the stock Intel cooler?
Hmm, I'd say do indeed give it a bump to 1.22 - 1.25 volts manually, also give your ram a bump up to 1.55, to see if that stabilizes things.
Perineum
Surrey, B.C.
ASUS board as well,
ST
I have seen this many times on Asus boards with the P35 / X38 and P45 chipsets.
It happens pretty reliably if you turn on your computer and the BIOS is partially through POSTing and you power off the PSU.
The next bootup will say Overclocking failed. Go into the BIOS, change nothing, then save. Your computer will boot up normally.
Basically for whatever reason the programming that allows overclockers to get back into the BIOS without clearing CMOS and erasing everything for a bad overclock is being tripped.
I would bet it's due to your system starting to boot up, stopping, then booting up again. I'm not sure why some systems do that (start booting, turn off, then on again) and others do not.
It is definitely not related to anything with Windows updates or your OS install.
Soultribunal
Mississauga
Okay, thanks for the info.
I've used ASUS boards for years and I'll be completely honest, first Time I had ever seen this come up.
ST
