OVERCLOCKING issues. =/
wingzero3002
New member
Alright, getting right to it:
Core i7 920
Asus P6T Deluxe V2
Patriot Viper Series? 1600Mhz cas 8
GTX275
Corsair TX750W
2X WD 640GB RAID0
Windows 7 Home Pre 64 bit
Right now it is running at stock
but i have had it up at 3.61Ghz easily. and i prolly consider myself a noob at oc-ing
then my computer had some problems, so i reformatted my computer, updated bios as well
and now. i cant get it back up to 3.6
i cant clock it to ANYTHING other than stock D:
which is really upsetting because i have an i7 at stock, when i bought it to be clocked ><
i have a feeling it is because i updated the BIOS?
any other ideas?
my board came with the bios version of......0504
then after the reformat it became 0610
thinking it was the bios problem, i updated it again.... to the current version of 0704.
Cooling is not a problem, as when i had it up at 3.6 before i was in aruond mid low 70s at load after a couple hours.
Cooler Master V8 is doing the cooling.
yea...
thanks =)
Chris
Toronto
Post your set up so we have some details, like this:
Here is my setup:
20x19=3.8GHz stable for 9 hours of P95 blend test.
Idle temp 44c. Full load with P95 74c max.
Ram at rated speed [email protected],8,8,24 1T
Stepping: D0
MB Intelligent Tweaker (M.I.T):
CPU Clock Ratio [19x]
CPU Frequency [3.8GHz] [200x19]
QPI Link Speed [x36] [7.2GHz]
Base Clock Control [Enabled]
BCLK Frequency (Mhz) [200]
Performance Enhance [Standard]
System Memory Multiplier (SPD) [8.0]
Advanced Clock Control:
Base Clock (BCLK) Control [Enabled]
PCI Express Frequency (Mhz) [101]
Uncore & QPI Features:
QPI Link Speed [7.2GHz]
Uncore Frequency [x17] (3400 MHz)
Advanced CPU Features:
Intel Turbo Boost Tech. [Disabled]
CPU Cores Enabled [All]
CPU Multi Threading [Enabled]
CPU Enhanced Halt (C1E) [Disabled]
C3/C6/C7 State Support [Diabled]
CPU Thermal Monitor [Enabled]
CPU Eist Function [Enabled]
Virtualization Technology [Enabled]
Bi-directional PROCHOT [Enabled]
CPU Vcore 1.22500V
QPI/Vtt 1.30000V
IOH Core auto
DRAM Voltage 1.64V
Advanced Voltage Control:
Load-Line Calibration [Enabled]
CPU Vcore 1.225V
QPI/Vtt Voltage 1.300V
CPU PLL 1.800V
>>>MCH/ICH
PCIE 1.500V [Auto]
QPI PLL auto
IOH Core auto
ICH I/O Auto
ICH Core Auto
>>>DRAM
DRAM Voltage 1.64v
