Overclocking Troubles
MBeau
New member
Hi,
I have an ASUS B250-F Strix MOBO paired with an i5 7600k. Now I got this MOBO because it was fairly cheap compared to some Z270 alternatives. I was worried that it wasn't capable to have the CPU overclocked, but ASUS assured me that the MOBO is able to overclock. Bottom line is I can not for the life of me figure out where/how to do it. I've watched plenty of tutorials and I'm pretty savvy when it comes to tech, but it just seems like I don't have the same overclocking options in the bios as others do. Did I buy the wrong board, or is there a way I can put my 7600k to work and overclock it? Please help!
Coach
Morden MB
B350... that is an AMD board right? i5 7600k, that is an intel CPU so ya. YOu have more than overclocking problems
JD
Toronto, ON
I suspect you meant B250? As far as I know, overclocking is only supported on the Z270 chipset.
