Pc bottleknecking???
Fake2591
Member
Saskatchewan
Hi, Im new to this whole forum thing but ya. Anyways.
My Pc is some cisnet thing. So I decided to add some new hardware to it.
First I bought a ATI Radeon x600 Pro. Well that seemed to help over integrated graphics :D.
Next I bought a 512 MB RAM stick DDR pc3200. I now had 1 gig and a graphic card. I was doin ok.
About 8 months later. I save up and I want to really overhaul my pc for gaming. So I bought an XFX Geforce 8800GTS Extreme Edition graphics card and a new coolmaster 550 W PSU. I notice that it barely out performed my radeon.. So I thought its gotta be my ram. So I buy 2 Samsung 1024 MB ddr pc3200 RAM sticks. Throw that in there... Pretty much the same as having 1 gig... So real difference. Lag in most games at 1280X1024. on medium... I'm pretty mad at this point...
Mc PC Specs. AMD Athlon 64 X2 3800+
3 gigs of ram
Coolmaster 550W PSU
Motherboard is some MSI piece of crap
have dvd burner and rom drives.
logitech g11
razer death adder mouse
I've asked a few friends and after running 3d Mark 06. I think it's my motherboard. and/or processors. All of my ram is 400MhZ Compatible. According to 3dMark its running at 333 MhZ. I have tried just using the 2 1024 Mb sticks without the 2 512's to see if there is any difference. No, there wasn't. My hard drive should be fine since I only got my pc back a few months ago from cisnet because the HD died apparently. I am pretty sure its this MSI Motherboard and processors limiting my Video card and RAM. Unless someone else can think of why its doing it :canadianwave:
P.S. Another thing I noticed is that my video card runs hot. I was wondering if it was due to my case coolings. Pretty crappy no real air flow. Was looking at Antec Nine Hundred case. Any thoughts on that :biggrin:
sswilson
Moncton NB
Your 8800 will probably be bottlenecked by the 3800+ no matter what you do, but might show an improvement if you can OC it.
Finding out what make your motherboard actually is would be a step in the right direction, but if it started out as a mATX board with ATI onboard I can pretty much guarantee that there are no OC functions on it.
The only real suggestion I can make is to stick with just the two 1 gig sticks and make sure they are running in dual channel. MSI normally doesn't use industry standard for which slots go together for dual channel so you might have to do some playing around to find the right mix (you might also have to muck about a bit in bios to get them set for dual channel).
Babrbarossa
New Brunswick
yeah- what sswilson said
The CPU si definitely bottlenecking the GPU- if it's a really crappy motherboard, OCing is probably not much of an option either. To bad that the 8800 can't stretch it's legs. It's like owning a Ferarri but never being able to leave the WalMart parking lot.
I am surprised that you didn't notice much difference over the x800 though- I wouldn't have thought that the old card was that close to the CPU limitation. What were your 3DMark scores before and after?
Jmac
Van Isle, BC
I have the same computer (Cisnet CA-BD901) with an 8800 GTS and it runs perfectly fine (7200 in 3DMark06, which is still bottlenecked, obviously, but it runs every game I throw at it at max settings (16x AA, 16x AF, HDR, etc.) ... I had to buy something quick because of my divorce (wifey took the computer) and this was on sale for $500, had good parts, and was easily upgradable ... and the X2 3800+ was going for $390 at the time :p
Oh yeah and definitely no overclocking settings in the BIOS, although you can underclock it if you want (I don't know why you would, but it's there :p)
sswilson
Moncton NB
Ok, here is my motherboard MSI Computer Corp. - Product
Just found it :biggrin:
I was thinking of getting this one, Asus M2N4-SLI NVIDIA Socket AM2 ATX Motherboard and an AMD Athlon 64 X2 5400+ 2.80GHz Socket AM2 OEM Processor in Canada at TigerDirect.ca
Looks like it should help me out alot...
Heh.... I had one of those mobos myself... forget about overclocking, there are absolutely no settings!!!!!
Keep in mind that you are moving to AM2 with the new gear you are looking at, and will need a set of DDR2 mem to go with it (yours is S939, thus DDR1).
I'd also have a good look at your PSU to see if it's really up to the task of running that 8800. Underpowered PSUs can drastically affect performance even if they manage to get the card up and running.
Jmac
Van Isle, BC
You guys should compare 3dmark scores then- is yours tweakable JMac?
Edit- just saw wilson's post..
Mine isn't tweakable, no ... If it were, I probably wouldn't be upgrading to a new computer this month ...
Before I bought it, I wrote down all the part numbers and researched them, all of them had 5 star ratings on Newegg (other than the DVD burner and Power Supply, both of which I was going to replace anyways), so I decided to buy it ...
I've been running it pretty much 24/7 since last April without any crashes, blue screens, etc.
Fake2591
Member
Saskatchewan
Well my marks for 3dmark 06 are, SM2.0 Score 2920, HDR/SM3.0 Score 3280, CPU score 1495. Then it says 6675 3D Marks
These are at res. 1280 X 1024 no AA or anything special just optimal settings.
