MvP_Tsunami
New member
- Joined
- Sep 2, 2019
- Messages
- 4
If you are only needing 1TB of storage, then yes, getting a 1TB SSD instead is a better choice. There's a lot of affordable options out there now. The Intel 660p might be the cheapest decent choice.
You could possibly look at going with a RX 580 instead of the 1660 too if you need to save a bit to offset the SSD cost. I think the performance is similar with all the driver updates AMD has done.
Corsair RAM is usually a little more expensive than other brands, so you might be able to save a bit there too.
