PC case recommendation - please help
yajdem
Member
Hello!
I would like to ask you for a recommendation on the purchase of a computer case.
I will use an ATX size motherboard in the machine.
The processor will be an Amd 7800X3D, which I will use with either an Artic Liquid Freezer II 360mm or an EKWB EK-Nucleus AIO CR360.
The power supply will be a Corsair HX1000i.
Last but not least, the video card will be an ASUS TUF Gaming Radeon™ RX 7900 XTX OC Edition 24GB GDDR6.
I would like to place the cooling fin on the top of the computer case, because I know that it is the most efficient and therefore the most ideal.
The money I could spend on it: ~ EUR 200 (£170, USD 218)
What I want is glass on the sides of the machine housing.
It is important to be as quiet as possible with good cooling performance.
I also like traditional houses and dual chamber houses.
What do you think would be the right choice for me? Even offering more.
Thanks!
What country are you in, or what sites do you have available to purchase from? Pricing is very different from one location to another.
Good cooling performance and quiet performance generally doesn't mix. It's either higher temperature for lower noise or the other way around. If you look at Dark Base 601 review, one of the problem is that it has poor thermal performance under high load.
I see you asked the same question back in 2018. So which case did you end up getting back then? Was it not good enough or you want to switch to a different look?
