PC Case Trouble
PigFreak
New member
Hello everyone it's my first post and I wanted to ask something. This is my build:
CPU:Intel i5 4690k
CPU Cooler:Cooler Master Nepton 280L
MOBO: ASUS Maximus VII Hero
GPU: MSI nVidia GTX 970
RAM: 2x4GB Kingston HyperX Beast 2400MHz
SSD: Samsung 840 250GB EVO
HDD: Western Digital 3TB Black
PSU: Seasonic X-750
Monitor: Asus VS247H
Now I would like to ask you something: First what do you think of my build? Second , and the most important question, which case do you recommend? This is a gaming build but I really need help with the case :biggrin: I was thinking of the Corsair 760T but is there a better solution? Thank you! :thumb:
Bond007
Nova Scotia
What do you link in a case?
Mid tower/full tower
airflow/ silence
watercooling at any point, or just air
closing front panel or not
budget
PigFreak
New member
airflow/ silence
budget
preferably a full tower (although I don't mind a mid)
Silence is a premium but I do need good airflow.
I need room for a 280mm radiator and as many fans as possible.
I don't mind any kind of front panel but the maximum budget is about 250$. :bananafunky:
PigFreak
New member
Where do you live ? Contry ?
http://www.ncix.com/detail/phanteks-enthoo-pro-full-tower-6d-98838.htm
Water coolers wet dreem. :biggrin:
Yeah that's probably the case I would go for with those wants. It was reviewed here:
http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/66255-phanteks-enthoo-pro-case-review.html
I live in Serbia and I think you can't find this case here. I'm looking into it but if it doesn't work out is the Corsair 760T the best choice?
