PC keeps shutting down
TTC
So I will be trucking along and all of a sudden it will reset. Its like it loses power. I have a 1000w fairly new PS. But the 2500k is like 4 years old and the mobo probably 1.5years.
You think the overclock has finally wore my hardware down? Where do i start? lowered the oc to 4.3 and still doesnt help.
yamawho
Rosemere, Qc, Canada
Check if any capacitors are swollen.
Google your mobo, there could be a known issue.
I did this on mine last year and it was bad IC's ... black screen. I sent the mobo the Gigabyte and they fixed it.
TTC
Yea it just blacks out. Ill list specs when I can.
2500k
asus z77 lk v
gtx980 for starters
KaptCrunch
Ontario
I see bios version for P8Z77-V LK
BIOS 1402 Improve memory compatibility.
also that power supply ?
if bios needs updating, use the Asus suite software to do so
you will see bios version on a cold boot or hit Del or F2 to check
TTC
The PS is less than a year old 1000w coolermaster. I can't see it failing. Another odd thing, when it does shut down sometimes you have to wait a bit. Unplug it, and cycle it on and off for 2minutes.
sweenytodd
Kelowna, BC
Black Screen has many variables,
examples are:
cpu overheating
videocard failing
psu failing
motherboard failing
ram failing.
TTC
Cant be a heat thing. Everything is liquid cooled. If anything its mobo or ram. Ill just keep using it until it wont turn on. That psu is supposed to be bullet proof.
